Thread: flywheel torque 03 to 99
    ok help what do i topque the 03 flywheel to on my 99 cobra
    Senior Member 50 BMG's Avatar
    Torque spec?
    Call Akuma or Dan I know they have the manuals.
    tight, worked for me for years
    gudentight...(german torque spec)
    Quote Originally Posted by 50 BMG
    exactly!
    but after working on acft/helos for 6 years my arm is always calibrated
    Mini Cooper matt's Avatar
    Cave Creek
    This should cover everything..
    "Syncromesh Transmission Fluid - Friction Modifier" GM part #12377916
    DEXRON III? (ATF) Transmission Fluid
    XT-2-QDX DEXRON III?
    Pressure plate-to-flywheel bolts 4.6L (4V) 33 lb-ft + 60?
    Transmission to clutch adapter housing bolts 26 lb-ft
    bellhousing-to-block bolts are torqued to 55 ft/lbs.
    PP bolts to like 25-30 ft-lbs
    Flywheel to crank ---- 63 ft lbs
    PP to flywheel ------- 33 ft lbs plus 60 degrees more
    Bellhousing to block--- 55 ft lbs
    Trans to bellhousing -- 26 ft lbs
    Trans front cover ---- 26 ft lbs could be called adapter, or input shaft
    retainer (removed to change input shaft)
    Trans rear ext hsing -- 26 ft lbs
    I German torque everything.........Good-en-tite
