Results 1 to 9 of 9
Thread: Parking brake light turns on
    Hey ive got a question. Ok so when im driving and i hit the brakes hard but not locking them up my parking brake light will come on and then when i let off the brake pedal it will turn off....??? any ideas? suggestions? Thanks
    Chris
    I think that is your ABS light as well. Not sure on that tho.
    Senior Member svtrichie's Avatar
    Phoenix, Arizona
    I believe that you are correct, something to do with the abs.
    probably low on brake fluid. just above the minimum, then you hit the brakes, the car lunges, the fluid swishes away from the sensor, and bam light on
    aight ill check that in the morning thx guys
    Your Ford abs light will say (ABS) in amber!! Your red brake light is either telling you that you are low on fluid or your parking brake is applied....
    Senior Member ttocs's Avatar
    gilbert
    quit pushin it so hard, problem solved........
    low on brake fluid, thx for the help
    Quote Originally Posted by 99WhiteGT View Post
    oooo what do i win jk
    remember, brake fluid is only low because it has gone somewhere. either something is leaking, or its time for brakes (or it was bled at one point and not filled up correctly)
